跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1366 个问题 查看全部
Can loop disease limit the camera?
Hi yall, so I’ve repaired a family member’s iPhone 7 with loop disease (we’ll send it to a repair shop far away that can do microsoldering to fix that.), but now that I’ve fixed the phone, its camera functions are completely gone. Both back and front. Now im wondering if i somehow maybe screwed something up. I’ve recconected both like 8 times. Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
A dodgy back camera can also stop the front from working (aswell as the flash light). Could also be board level though.
这个答案有帮助吗?
得分 1
添加一条评论
as chris said back camera can cause front to not work as well. try disconnecting the back camera and see if the front camera works (may or may not).
also, what repair did you do? I’m assuming a screen replacement (most common repair on a phone after all). Check to make sure the prox/front camera flex cable didn’t receive any damage as well.
Clean connectors for both front and back cameras. Power cycle device (disconnect battery and hold power button for 10-15 seconds to flush all power out of the board).
If nothing else you can try to do a factory restore via itunes and see if there is a software glitch that caused the issue. That’s about all I can think of that may help restore functionality though beyond replacing the (most likely just the) rear camera, which for some reason is more expensive on the iphone 7 plus than any other iphone I’ve seen including xs max.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lochy59 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 113
