跳转到主内容
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
220 个问题 查看全部
Is there a trick to replacing the battery cover screws?
Everytime I attempt to put the screw back into the battery cover,the screw seems to change polarity flip upside down or jump out and stick to the side of the case..
Is there a good tip /technique to doing this I wonder?
I’ve got this far after first time battery and display renewal,so this is infuriating to say the least !!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Magnetize a Screwdriver
the screws will then go to the screwdriver
One way and may explain the theory
https://www.wikihow.com/Magnetize-a-Scre...
这个答案有帮助吗?
得分 2
1条评论:
Thanks Bill
I was thinking that was why it was happening it seemed the screwdriver was changing the polarity hence the flipping over of the screw as soon as the magnetized driver and screw got near the hole -like it was being repelled like magnets do when you try and push them together if you known what I mean..
Never had that happen before so what was going on there I'm not sure...It shouldn't be spitting the screw out should it!
In the end I used an actual magnetic bar of the same diameter as the screw head and was able to start it off in the hole so it wouldn't be able to jump out and then screw it fully down with the driver...lucky to find that magnet , and now I'll keep it safe in my tools.
Thanks for the link I'll check that out
完成的
添加一条评论
添加你的答案
EAMONN COLLEY 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 99
