跳转到主内容
This PC is a Dell Inspiron 3000 Series laptop with an AMD processor and a non-touch display. It's model number is 3541.
20 个问题 查看全部
horizental pink line flicker on the top of screen on low brightness?
while making brightness level to low a pinkish line appers on the top of display and window freezes and shut down but if i increse brightness to high it goes away but after using on full brightness after sometimes suddenly window freezes and shutdown.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
could be the LCD panel or the GPU. Connect an external monitor. If that show a good picture you know it is most likely your LCD panel that needs replacing. If the external monitor is showing the same issues, you have having problems with the GPU on the logic board and will have to at least disassemble your laptop to inspect. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
sujan pokharel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 9
总计 144
