跳转到主内容
Find repair information on the second generation Toyota Tacoma.
20 个问题 查看全部
4wD indicator and 4 low lights on
Hello , 2005 Tacoma 4WD light and 4Lo lights blinking when ignition on . 4WD is in op. Plug in snap on scanner to data link port , and everything works fine , lights go out . Unplug scanner and lights flash immedialty
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Either your front add motor is bad or the 4wd selector switch is blown.
这个答案有帮助吗?
得分 0
2条评论:
I’ll check the switch when I get home , it’s just does t make any sense that everything works as designed when I plug my scanner in , then quits when I unplug it , I’ll check the switch and the park neutral signal today
完成的
What was the fix? I am having the same issue right now...
完成的
添加一条评论
添加你的答案
Sean baldwin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 3,187
