跳转到主内容
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
220 个问题 查看全部
Single horizontal strip in the middle is unresponsive but ghost clicks
Ive had my iPad mini 2 now for around 5 years now and about 2 years ago I noticed the middle of my screen went unresponsive to my touches. The best way to describe where it is is if you pull up the google app and have the screen vertical, it’s at the exact location and has an identical width as the google bar. There are no screen fades (white/ black lines) either. It didn’t bother me to badly, you can turn the screen horizontal, click where you want to go, then reorientate the device and go along your way. That was until it rapidly started to ghost click along that line after handling the device for awhile. I.e. you can keep it on a table, watch an entire movie and not have a problem until you pick it up and start to walk around with it in your hand. To stop it you just push sleep, wait a few seconds, then turn it back on. I have no idea what the issue could be, I haven’t seen any forums on this specific problem but could really appreciate some solutions, thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It seems your digitizer flex connector is loose. The only way to confirm this would be to open the device with heat and patience and check it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alex Loftin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 45
