跳转到主内容
Samsung的旗舰手机,Galaxy S8,发布于2017年4月。
304 个问题 查看全部
Samsung S8 how to remove motherboard metal shields/cover
I have this S8 that works but there is some internal component that gets mad hot and drain battery.
How can I correctly remove the metal shields? I tried with heat gun, set it to 400+ Celsius and taking it with tweezers on corner, but nothing, they didn't move at all. With the EMI shield of iPhones this method worked well but it seems I got no luck with s8.
Any tips,???? I don't want to frie the board :-) thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
https://www.youtube.com/watch?v=GRmY-4HK...
This is probably your best bet! Great Video!
这个答案有帮助吗?
得分 0
6条评论:
Hi Jessica! Thanks for the response. I've watched all the video you linked, but unfortunately it is missing the process I'm referring to in the thread.
I meant the metal shields that cover all the little ICs and electrical components.
I've updated the OT, now there is a image of it to be more clear. Should have put that from the beginning! Doh :-)
完成的
I mean if you still wanted it to work it is part of the full motherboard so there is really no way to take that out and still use it..
完成的
You can't remove those shields? So basically you are telling me these boards are not fixable?
完成的
You are gonna have to replace the whole mother board.
完成的
like the whole green piece its attached to
完成的
显示更多的1条评论
添加一条评论
Try temp 360 degrees celcius and air flow of 30. It is also advised to use helical hot air gun, they provide a wider surface area coverage.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Denv 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 990
