跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
White lines on the display and still after replacement
I had an iPhone 5 that was working properly, but I dropped and it cracked the display and started to show white lines on the display (
) so I replaced the display and it still show the lines (
) so I tested the new display on another board and it works normally (
), what could it be the issue?
when the screen first light up you can't see nothing on the display, just white, but if you wait a bit it starts to get better, but the lines still visible.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It’s most likely a bad lcd connector on the logicboard. It will need to be replaced by a professional micro-solderer
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Heitor Scatolin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 26
