跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
How to shut off iPhone XR with a broken screen
So I was trying to replace my broken screen, and in the process I accidentally broke it further. No big deal I thought, since i’m replacing it anyway. Then before I got all the adhesive off, I accidentally turned it on. Is there a way to either shut it off without the screen or safely disconnect the battery? Or do I have to wait for the phone to die
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Press vol up, then volume down then press and hold power button.
Do this until you see the screen go off, then on again then off. Usually this makes the phone stay off without itself turning on again.
这个答案有帮助吗?
得分 2
1条评论:
this dosent work it turns back on in minuntes, esentally restarteding the phone
完成的
添加一条评论
So it’s actually to press up down and hold power button until screen shuts down, and then push up and power together and hold until it shuts down again and there you go!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christian 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 47
总计 22,630
