跳转到主内容
加入维修社区 - 创建账户
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
Apple Store Can't Fix Low Speaker Volume
My wife’s iPhone 6 plus has very low volume, barely audible. This is intermittent - occasionally the volume goes back to “normal,” but the low volume problem is present 90% of the time. After trying a software fix via settings, we brought it to the Apple store in Dedham, MA. They were unable to diagnose the problem. And, they said they could not replace the speaker in this phone. My wife uses the speaker for GPS driving directions, so we are thinking of getting her a new iPhone 8 plus, at a cost of over $500. I’d appreciate any help the ifixit community can provide to solve this problem. Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
This sounds expensive - do you think it's worth the expense, given that the phone is five yrs old, and a new iPhone 8 plus would be around $500?
完成的
添加一条评论
1个答案
已选择的解决方案
There are three main components involved here; the speaker itself, the Dock Flex which connects to the speaker to the logic board and the logic board itself. The easiest thing to try is a replacement speaker but those rarely go bad unless there was water in the phone. The Dock Flex can fail from using low quality chargers but it would not normally affect the speaker and besides, you haven’t said anything about charging issues.
The final option is the logic board itself. The 6 Plus is subject to flexing so perhaps the speaker amp section of the logic board is damaged (could also be caused by water). The only way to know for certain is to open up the device, inspect for liquid damage and start testing with some known-good parts if there doesn’t appear to be an liquid.
If you don’t want to invest time and parts, then a good shop should be able to do the basic troubleshooting and if micro-soldering is required, you’ll need to find a shop that can offer this service.
这个答案有帮助吗?
得分 4
1条评论:
If it's just the speaker or Dock flex, it shouldn't be expensive at all. However if it requires a micro-soldering repair, then you will have to make a harder decision. If you have the money available to upgrade, it probably makes more sense to do that. If the budget is tight, then a repair prolongs the life of your device and is a cost effective solution.
BTW a micro-soldering repair by a reputable shop would probably be in the $100 range (it would be cheaper if it is only a connector for example). Some shops charge much less (but quality of work is a consideration) while others may charge more. Shop around if it comes to that.
完成的
添加一条评论
添加你的答案
Gesmer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 351
