跳转到主内容
Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
210 个问题 查看全部
Apple watch not charging after battery replacement
I replaced the battery of my Apple watch original (screen & force touch sensor as well).
now it’s not charging. It shows the Apple logo, wich fades to red after a few seconds. About half a minute later is repeats this.
Tried to reboot by pushing both buttons for 30 seconds, but no result thus far.
Anybody have a solution?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
5条评论
The apple logo keeps displaying on apple watch maybe? Worth a read thru anyways.
Personally when encountering situations like this, I disassemble the unit (and sometimes inadvertently myself),swear a bit, try to identify the points in the repair sequence where I mucked up, then reassemble the unit (usually between applying band-aids to various parts of my body), swear a little more energetically at components that should go together in less than 30 seconds but take up an hour and a half to accomplish and finally finish up with the unit working again (and sometimes too, find myself yelling, "What in the %$#$&8yh7^% is wrong with this thing??????") Third time through the process it usually works though due to the fact by that time I have intimidated the H E double hockey sticks outta it! :-)
完成的
I just changed the battery in my series 2 apple watch because it was showing the green snake and now it won’t turn on i’ve disconnected and reconnected the cables multiple times and it’s still not turning on. I have even tried using the old battery and it still wouldn’t turn on. What should i do?
完成的
Have replaced Series 1 battery (twice) and both times battery fails to charge. Battery on charger shows in Power reserve mode (less than 10%?) showing a Green lightning bolt (top LT corner) and Green local time (numbers only, ie. 7:23). When I remove watch from the charger (previously cleaned contact points on both) the Lightning Bolt changes to "RED" (top LT corner) and local time stays Green on top RT of screen. The watch ran perfectly on the battery power as received from iFixit lasting a full day of wearable use; and this is where the problem started.. charging! The battery gets quite warm but does not charge. ON the first battery replacement the charging cycle became shorter each day over three days until it totally failed. IFixit sent a replacement battery and it is not doing any better. This must be a charging circuit problem?! Any ideas??
完成的
Hi Wayne, I too am on my second iFixit battery with exactly the same issue that you’re describing. Annoying thing is, it does recharge - but only after leaving it for a month to fully discharge to dead-dead. I can then get one full charge out of it, but then the problem repeats. So basically for 2 days a month i can use it, and the rest of the days it won’t charge.
完成的
I'm afraid I have to add a me too. Just replaced the battery in my Series 5 and thought I was home free. The battery charged once and now refuses to charge. Just like the OP it shows the apple logo and reboots. I'm not looking forward to opening this again. If anyone reading this has a better idea than replacing the iFixit battery, please speak up!!!
完成的
添加一条评论
4个答案
已选择的解决方案
Thanks, Sems the replacement battery was failing, replaced it Seems to werk fine Now…
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
If you use a third-party charging stand, take the charging cable that came with the Apple Watch. If you cannot charge the Apple Watch or a message appears stating that charging with this accessory is not supported, follow these steps. Make sure that the Apple Watch magnetic-charging cable is fully inserted into the USB power adapter, then check that the adapter is fully inserted into the power outlet. Make sure you are using the magnetic charging cable and the USB power adapter that came with your Apple Watch. Remove the plastic film completely on both sides of the charger. Make sure that the back of the Apple Watch and the charger are clean. Put the Apple Watch back on the charger. The charger magnets will align the Apple Watch, and a green lightning bolt icon will appear on the screen. If the Apple Watch still does not charge, force a restart. Press and hold the side button and Digital Crown for at least 10 seconds until the Apple logo appears. Try a different magnetic watch Apple Watch charging cable and a different USB power adapter. If the Apple Watch is low, connect it to the charger and wait a few minutes until the charging icon appears.
这个答案有帮助吗?
得分 2
添加一条评论
Update your Apple watchOS
Many issues are caused due to outdated firmware and bugs, hence it is always a best practice to keep your iOS and watchOS updated as soon new update rolls in. This is how you can update your watchOS:
Step 1: keep Apple watch connected to charger
Step 2: On your iPhone, go to Apple Watch app
Step 3: Tap on "My Watch" tab inside the application
Now tap, "General> Software Update", download the update and wait till the process is completed.
Restart Apple Watch
Step 1: Open "Settings" app on your Apple Watch
Step 2: Navigate to "General>Reset>Reset All Content and Settings"
Step 3: It will prompt for passcode if any and at last confirm selection to reset your Apple Watch
Wait for the process to end, your Apple Watch will be just like it was new.
https://www.youtube.com/watch?v=pZyOHCy4...
这个答案有帮助吗?
得分 1
添加一条评论
I had a similar issue. Turns out that the battery was not 100% seated. Once I opened the unit up, re seated the battery in its plug, the ‘charging’ picture came up.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tobi 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 46
过去 30 天: 152
总计 10,995
