跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Charging problem and boot loop
I have a iPhone 6s plus that I've had for ahwile that my uncle game me to fix so I order a brand new screen and I plugged the phone it a charger and when i start it up it's starts a boot loop so I've had my experiences with bootloops and know how to get around them so I unplug the charger to hard reset the phone and the phone instantly turns off . It only turns on when it's connected to the charger and goes to the boot loop so I connected it to a computer to restore it and when it easier goes to restore it the phone restarts 3 times and I get an error on iTunes saying there was an error trying to restore iPhone also it doesn't get to the load bar thing it just keeps restarting to the plugged in to iTunes prompt on the phone. So do I have to buy a new battery or replace the charging port?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Did it give an error code in iTunes??
完成的
Yes it was an error in itunes I have to retry it again to check and get back with you on the error type
完成的
添加一条评论
1个答案
已选择的解决方案
This sounds like a battery problem if the phone has been sitting around for ages. The charge port should be fine if it is detected by iTunes. Install a new battery and there’s a good chance it will boot up or can be restored by iTunes.
这个答案有帮助吗?
得分 1
1条评论:
No your wrong, I have the same problem. If it was easy as replacing the battery no one would bother using the web.. didnt you know 70% of iphone users replace there own batteries.
完成的
添加一条评论
添加你的答案
Markell Swain 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 453
