跳转到主内容
ThinkPad released in 2011. This version of the T420 is thicker than the T420s and lacks integrated USB 3.0. The T420i uses the same chassis, so most T420 repair guides work interchangeably.
16 个问题 查看全部
Why is my Intel Centrino Ultimate-n 6300 AGN Driver repeatedly disab
Im using Windows 10 :[.
It randomly n repeatedly disables my internet.
At times i show ‘Available Connections, yet No available Wifi.
That is Troubleshooter only tells me the obvious.
Your ethernet is not plugged.
That would make sense when im sitting at The Coffe Shop wondering why i have a choice to manually turn on wifi. (Why was it turned off)
The drop down says.
Manual
Restart in 1 hour
Restart in 1 day
Etc…
What are thes choices and why are the here instead of “Choose Wifi conecction".
Thank You.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @nyazilla
I have some suggestion,
try updating the drivers and see if it works.
https://downloadcenter.intel.com/product...
Install Hotkey Features Integration under Software and Utilities
https://pcsupport.lenovo.com/sg/en/produ...)
If it does not work, try blocking pin 20 and see if it works.
Sometimes faulty wifi switch can cause this weird issues.
https://www.eevblog.com/forum/beginners/...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ian Storm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 665
