跳转到主内容
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 个问题 查看全部
Super sensitive home button after digitizer change.
So I just did an digitizer change on an iPad mini 2 and now I have a super-sensitive home button. Any one knows why? I just have to lay my finger on it an it will react. Double tapping it will bring up Siri. Also putting some pressure on the right side of the home button on the glass will give the same reaction as to using the home button. Some problem with grounding points?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Use the home button that on previous touch,The new one with touch not working well i also faced that issues before.
这个答案有帮助吗?
得分 1
添加一条评论
Did you reuse the old home button?
The new digitizer May have a slightly uneven or differently sized hole or button. It could have uneven pressure on it.
这个答案有帮助吗?
得分 0
2条评论:
Could also be due to not having yellow kapton tape behind the screen at the bottom digitizer touch screen borders and the home button cable.
https://images-na.ssl-images-amazon.com/...
完成的
Screen had kapton, although no protection for the home flexcable. Put some plastic over it and the issue dissapeared.
完成的
添加一条评论
添加你的答案
patrick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 43
