跳转到主内容
The Nokia 6 became globally available, along with the new Nokia 6 Arte Black Flipkart, Amazon, and Snapdeal special edition models in January 2017. The Nokia 6 includes model numbers TA-1021, TA-1033, TA-1000, TA-1003, TA-1025, and TA-1039.
25 个问题 查看全部
Repair faulty 35mm audio jack
Hi,
The audio jack on my Nokia 6 stopped functioning. At first it would connect intermittently , then you needed to position the jack in a particular way to get stereo sound and now it’s outright not working or connecting when you plug in the jack.
Any ideas on fixing this issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
I assume you’ve tried different headphones? It definitely sounds like a loose connection. You can try cleaning the port out with compressed air and a tooth pick with some rubbing alcohol(dipped on the tooth pick)
if it’s not due to dust,it’s probably a bad port. It would require a replacement. This means disassembling the phone. Sometimes it is soldered on the board,other times it is a separate part that plugs into the board.
You can also get Bluetooth earbuds if the above is too much of a hassle.
这个答案有帮助吗?
得分 0
添加一条评论
I had this problem on a Nokia 6.1. I found the plug was not pushing in all the way. After a careful look I realised the jack socket was a closed space and sand or dirt had somehow accumulated in it, stopping the plug entering properly. After switching the phone off for electrical safety I gently scraped around the bottom of the socket with a fine pin, loosening debris which then shook out when it was turned upside down. Powered back on and all had returned to normal.
This may not be the answer for you but it is quick and easy and a simple fix if it works.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Moseti Masese 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 697
