跳转到主内容
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
153 个问题 查看全部
iPad 6 Home Button metal contact ripped
Hello, I successfully managed to remove a cracked screen from my ipad 6, but right at the end, the rectangular metal contact halfway down the home button assembly ripped. Can I access my ipad contents if I wire this damaged home button in? Or is it vital to replace it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
最有帮助的答案
If you mean the Touch ID button flex cable broke(the little grey metal rectangle attached to the flex itself broke),it is repairable by a microsolderer. Other than that,you can maybe go to accessibility settings,assistive Touch. This allows a virtual home button function on screen.
The Touch ID function is tied by software to the logic board itself. So it is not replaceable unless apple will program a new one,which they would not do since you’ve opened the iPad…you can buy a home button replacement,but you will lose Touch ID function. Only physically pressing will work.
The only way to repair your Touch ID flex cable is to have someone that microsolderer tiny things fix it for you.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Anu Anand 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 920
