跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
399 个问题 查看全部
My invert colors aren’t turning off when it says it’s off
So basically, i did nothing with my phone except watch YouTube videos. Then when I woke up I just see everything inverted colors. So I check settings to try and turn it off but it says its already off. So I was super confused. I even restarted my phone. Please someone help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
3条评论
Inverted screen or colour combination??
完成的
Both for me I don't know what to do
完成的
Go into your display and text size In settings and make sure your classic and there's another one both make sure both inverts are off just make sure they're both off the siri will say that they're Off but they are not so make sure they're off that should fix the problem
完成的
添加一条评论
2个答案
最有帮助的答案
You can try to reset all settings. This resets WiFi connections,Touch id,password,etc. no important data is lost. No pictures or anything else is deleted. Only settings. This could fix a software glitch.
You can try to update the iOS as well. This can be a bug in your current iOS version.
Worse case you can factory reset the iPhone and set it up as new. This usually fixes any software issues.
这个答案有帮助吗?
得分 2
添加一条评论
Go to siri and say turn off inverted colors
(Idk if this will work I’m just trying to help)
这个答案有帮助吗?
得分 0
1条评论:
Thank you so much, I tried everything else but nothing worked then I tried Siri and it finally worked
完成的
添加一条评论
添加你的答案
kieu nguyen 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 30
过去 30 天: 121
总计 3,529
