跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
No wifi but bluetooth OK?
Hello - I have an IPhone 6 S plus, the wifi is greyed out but the Bluetooth turns on and can pick up BL devices. In Settings / General /About a wifi address can be seen.
Have replaced wifi modules and antennas - the symptoms don’t match the classic wifi IC failure and the phone is not getting hot.
Any ideas?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I thought someone had answered this.
Why is my WI-FI greyed out?
1.       No power getting to the Wi-Fi chip
2.       Oxidised pads under the WI-FI chip
3.       Brocken trace under WI-FI chip
4.       Damaged WI-FI chip
5.       WI-FI chip not communicating with the CPU
If you have blue tooth you can rule out number 1.
这个答案有帮助吗?
得分 1
添加一条评论
First re-hot the WI-FI chip and check.That must be WI-FI module faulty because both have enviled in same chip.
Remember that you need to unbing WI-FI with Nand by removing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Louis Kaldmaa 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 156
