跳转到主内容
The Acer Nitro 5 AN515-53-55G9 is a laptop targeted towards budget gamers. It boasts 256 GB of storage, Nvidia GeForce Graphics and an Intel i5 quad-core processor at a more affordable price than most gaming laptops.
My laptop is not turning on
Ok so I left for this morning and left my laptop on hoping it would go to sleep it did now it’s not turning on
what do I do this laptop is just problem upon problem
p.s it was connected to monitor and was left on charge
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
I take it the computer won't boot up from a total shutdown and not just from sleep mode and nothing is displayed on your screen when attempting to boot up. (that point is not clear from the contents of your query) If that is the case then you need to either try a replacement charger or use a multimeter to check your current charger is working properly and also the battery voltage. You can try taking out the battery and seeing if the computer will boot from the charger itself.
完成的
Don’t I have to remove the back panel and pull the battery out. Is it not put in the laptop with glue
完成的
Hi,
Here's a link to the ifixit Acer Nitro 5 AN515-53-55G9 Battery Replacement guide which may help.
完成的
添加一条评论
1个答案
try a multimeter and see if there is voltage coming from the charger and the battery port. If there is no voltage from either you battery needs replacing or your charger needs replacing
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Waqas Choudhry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 11
总计 1,331
