跳转到主内容
Released July 12, 2002. Identified by model number K45SSWH.
34 个问题 查看全部
Motor shuts off at high speed
When i move the lever to #8 and #10 the motor shuts off. I normally don’t mix at high speed but it was by chance i moved the lever to those positions and discovered the problem. Any assistance would be great. Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Quoted from the following link:
"If your mixer is only working on certain speeds, you might need to replace your circuit board. Don't worry, follow this guide on how to replace the circuit board."
KitchenAid Classic Mixer K45SSWH Circuit Board Replacement
Probably a good starting point if you are thinking of doing the repairs yourself. Just make sure you unplug the unit from the AC wall receptacle before undertaking any repairs.
完成的
添加一条评论
1个答案
My theory is when you increase the speed above certain level your mixer will start vibrating, this vibration may trigger the safety feature and that causes the motor to stop, to prove that, you need to set the lever at #7 and shake the mixer, if it stops then my theory is correct.
Be careful please !
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anna C 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 13
总计 1,132
