跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
Vibration doesnt work accept home button
Vibration is only working in home button feedback but not in other cases like the system wide haptic feedback or vibration on ringtone.
i severely broke my phone & had to change the casing by placing my motherboard onto another iphone 8 plus casing which was icloud locked.
After that I’m facing 4 problems
  1. Haptic feedback works only on home button (tried changing setting and restore iphone)
# No airpod prompt when I open the lid, cant connect it instantly, gets disconnected often
  1. low wifi range
  2. Most often only 2 bars in cellular network indicator.
  3. can anyone suggest me a fix?
  4. thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
  1. low wifi range
These two more then likely caused by incorrect assemble of the antennas
you need to back track on your work
iPhone 8 Plus Wi-Fi分集天线修复
这个答案有帮助吗?
得分 0
1条评论:
Thanks @edigitcom
And about taptic feedback?
完成的
添加一条评论
Swap the vibrator over so its using the original.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nazmul Hossain 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 352
