跳转到主内容
White Screen of Death + Corrupted in iTunes
My iPod Nano 3rd Gen recently stopped working. It shows a white screen and iTunes says it’s corrupted. I have tried normal restore and DFU restore. I have also opened it to check the display connector. Is the NAND dead? Is the display dead? The display has a line in it, and the iPod clicks. It makes me feel bad because this was my first handheld Apple device. Please help me!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hello. I’ve seen this a lot from when I repair broken iPods. The white screen of death is fairly common. Usually I don’t bother repairing this issue because it is usually caused by loose or damaged components on the motherboard from dropping it or age. You could open it up to see if there’s anything obvious but you are better off replacing it (Or at least replacing the motherboard) It is fairly cheap to replace the motherboard yourself but buying a new one isn’t going to cost much either.
这个答案有帮助吗?
得分 0
1条评论:
I don't see any damage internally. Could this still be board-related?
完成的
添加一条评论
Thanks for sharing this discussion as I also wanted have the similar answer. But if your device gets interrupted so you can get Geek Squad Protection Plan to experience better work flow.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
TheYootz Media Group 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 108
