跳转到主内容
加入维修社区 - 创建账户
The 2008-2012 Ford Escape features a revised front and rear fascia and restyled LED tail lamps.
Why is engine light in
Engine light stays on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Take it to an Advance Auto Parts or AutoZone and they will read the engine diagnostic trouble codes for free and give you direction as to what the cause is and what parts may be at fault. Plus they should be able to clear the code and the light will go out. It will return in a short time if the issue has not been addressed.
Some folks are comfortable leaving the light on provided the vehicle runs and operates okay. Sometimes you will have a code and check engine light for a somewhat minor issue but it could lead to a larger issue.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
sethklink 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 633
