Hi @bobertron12720 ,
Was there a power outage or storm between the time that the TV was on before you went to work and when you got home?
If so there may have been a power surge that affected the components on the board(s).
Perhaps, if there was a storm etc, the TV may be covered by your home contents insurance policy. Worth a check.
If there was no storm or outage then how old is the TV. You say it is a 2018 model. Is it still covered by the manufacturer’s warranty period?
If so follow the directions in the manufacturer’s warranty statement (it is possibly in the TV’s user manual) about how to make a claim for a warranty repair or replacement.
If it is no longer covered by the warranty then as you have already found one problem with the TV (and there may be more, the one you found may be the only “visible” problem), without a schematic diagram (and Toshiba does not release them publicly) it will be difficult to find.
Since it is not showing any signs of power perhaps replacing the Power board may be the best option to try first and hope that it took the brunt of whatever happened and that it did not affect the rest of the TV. Was it left on when you left for work?
Here’s a link to a supplier of a power board for your model.
It is only shown to give you an idea of the cost of the board. There may be other suppliers that suit you better. Just search for 43LF621U19 Power board to get results.
Important: Check that the board number printed on the power board in your TV matches exactly what is shown in the link or from wherever you decide to buy the board.
Also if it was a storm or outage that knocked out the TV then perhaps connecting the repaired TV or a new TV (if you get one) to the power via a surge protector may be a prudent move in the future. Just a thought.
5条评论
Same problem only no burning. I checked the power socket and still nothing. Took off the back plastic cover and yes 23 screws later, everything seemed fine, nothing burned. It's our second year with it. What can I do?
由 Norma Yudit Medina Medrano 完成的
I figured out how to fix this today after reading all of the posts that said its "unfixable". The problem is due to Chromecast setup mode being stuck, if you have connected the tv to your wifi previously you will need to do the following
1. Using a phone or other google device, download and setup the "Home" app from google
2. The app should detect the tv on the same Wifi as your phone even with the tv being completely dark, (no screen, no red light)
3. Complete the tv's chromecast setup and skip through all of the other streaming bs, you don't need it for this
4. Once it has completed, the phone should indicate that the tv is on "stanby" or something to that nature. Essentially the black screen and no red light are due to chromecast having an invisible non-responsive "screen saver"
5. Hold down the power button on the side of the tv until you see the tv reboot, keep holding until it fully powers on and asks you to complete setup (language, time, tv channels, etc. )
6. At this point you should be good to go.
由 Landin 完成的
This worked. It was my chrome cast. My tv had all the problems you mentioned above, so I almost trashed the tv. Thank you so much!
由 Gucci Mayne 完成的
Actually, it’s back to what it was doing before.. looking at having to replace this tv now
由 Gucci Mayne 完成的
I have a problem with the power card on my Toshiba TV model 42WL66E , no Spar part available because it's an old TV .
Please advise
my email maliice420@gmail.com
由 Ali 完成的
