跳转到主内容
Guides and repair information for Hoover vacuum cleaners.
36 个问题 查看全部
pet hair removal attachment stopped working
i have a hoover hurricane which works ok but the pet hair removal attachment has stopped working, i have put it in my friends hoover and it works, i have cleaned all the filters and the dirt bin but it still does not wok?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Did you check if there is a blockage in the hose?
Here’s a link that may be of some help.
Scroll down and click on No Suction not picking up > Check for Blockage in hose.
这个答案有帮助吗?
得分 2
4条评论:
there is no blockage as the hoover works when picking up dirt, however i have noticed a slight burning smell whilst vacuuming
完成的
Hi,
Only suggested the blockage because as the pet hair removal attachment is suction powered it may require more suction to operate than the normal attachments.
A slight burning smell may be emanating from the motor getting too hot. Vacuum cleaner motors rely on air passing over them to keep cool.
Just verifying that you cleaned the exhaust filter on the front of the cleaner as well?
完成的
yes i did that and its all clear of debris do you have any other suggestions as i have tried everything many thanks william
完成的
Hi,
Getting back to the burning small the only other thing that comes to mind is that the motor may have a few shorted wires in the windings and is not producing enough power.
If you have a power meter - example only (or one suitable for your location) or access to one, you could measure the power consumption (wattage) of the motor in your vacuum cleaner when it is operating (with /without the pet hair removal tool) and compare it to your friend's hoover (assuming it is of similar rated power consumption) and see if it is the motor that is the problem.
Just measuring the resistance of the motor windings, using an Ohmmeter may not be accurate enough to give an indication of a problem one way or the other.
完成的
添加一条评论
添加你的答案
william.mullan1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 1,291
