跳转到主内容
The Dodge Journey is a mid-size crossover SUV manufactured and marketed by FCA's Dodge brand since model year 2009, with a mild facelift for 2011 model-year.
27 个问题 查看全部
2009 Dodge journey revs high rmps while driving.
When I drive 30 rpms at 3000 40 4000 50 5000 60 6000 rpmsut has a review while driving transmission not slipping I can still catch speed just rpms and reving as get faster. I have been told many things and noone sas same thing. Any ideas
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
My car did the same thing. I would have to pull over, shut the car off for a bit, start the car back up and then go through the gears just to make it stop. But in the end. It comes to find out that the transmission solenoid was going out. Now it has gotten to the point that I can't drive the car at all. So now I'm in the process of finding out how to replace it myself.
完成的
添加一条评论
1个答案
You are probably in limp mode, is what the vehicle does signal you there is an issue that needs correction. Stop by auto parts store to get a free diagnostic code reading or take it into a shop. Sometimes I've heard that disconnect in the battery will reset the computer, Evenstill if it's a major issue it will just reoccur. So honestly the best method is to get it fixed please make sure you go to a mechanic you can trust I've ended up spending over $5000 just trying to identify what's putting my car in that mode
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
emilyisadork7 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 19
总计 595
