跳转到主内容
Xbox One X (机型型号 1787)是微软推出的高性能游戏主机,替代 Xbox One S 。这款主机发布于2017年11月7日。
Xbox One X Flashing Image and Crackling Sound
I have the answer for this, but I have to ask the question first it looks like.
Is your Xbox One X (Maybe S as well) image flashing to black randomly and sounds cracking? Look to my answer below for my initial issue and mt process to find it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I'm not that experienced with board repair but I believe I found a fix for an issue I ran across, and others as well. I didn't find much on the web or other groups expect people experiencing similar issues with no legitimate fix.
So a customer (co-workers brother actually) brought me an Xbox One X that the screen would go black after long hours of gaming. Sounded to me like it was over heating. Microsoft puts some really high end thermal compound on their chips, keeps them really cool, and the Xbox has never had problems over heating (<--Sarcasm)
Easy fix, cleaned up the system, a bit dusty, and applied some Thermal Grizzly.
Here is where my other issues came up.
Upon turning on the device after about 5 minutes the screen would begin to cut to a black screen then back on randomly. It wasn't like the screen wasn't receiving a signal, just that there was no image. I would also get some nasty crackling and popping sounds from the speakers.
What the !&&* did I do to this thing.
I was searching the internet for hours, I found a lot of people with issues regarding switching back and fourth between 4K and HD that would work, but their issues of "flashing screen" weren't quite the same as mine. I did however come across a YouTube channel TronicsFix. He was working on an Xbox one S that had no image at all. He ended up replacing the HDMI Controller IC right below the HDMI port. I don't believe his fix worked for him, but by using my brain and deductive reasoning I figured if the GPU had issues, I wouldn't get an image at all, and this IC he was referring to controlled timing and processing the signal, it had to be it.
Managed to find one in eBay. Replaced it and it worked!
I couldn't test if I fixed the initial issues of the over heating because I couldn't convince my manager that I needed to play 5 straight hours of Halo on the clock. But since the customer was a brother of a co-worker I explained that to him exactly, and he said he'd give it a shot. 3 months later, I haven't heard form him.
I'm kicking myself for not taking photos of the process to share with you guys. I also am not sure what led to the flashing issues, if that was something I did or just the original issues got worse. I hope this helps someone in the future.
Part is TDP158 HDMI Retimer IC
Link to part here: https://www.ebay.com/sch/i.html?_from=R4...
这个答案有帮助吗?
得分 0
1条评论:
Yay's and kudo's plus thanks for the share! :-)
完成的
添加一条评论
添加你的答案
Jeff Caauwe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 5,844
