跳转到主内容
Device repair guides for the 2018 Motorola Moto Z3 smartphone, model number XT1929-17.
19 个问题 查看全部
My display wont turn on
Okay. so today my replacement battery came in (yes)! It was definitely in need of a battery considering how the battery showed signs of swelling when I took it out. With that said, I have a new issue: the display.
My phone’s screen will no longer turn on. I tried reseating the ribbon cable, to no effect.
Has anyone else had this issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
I have had the same issue try unplug the battery then connect the display then plug the battery in , that worked for me even after I replaced the display with a new one , if it don’t work the 1st time try it again , then ribbon sometimes is not seated so good but always unplug the battery , then connect the display then the battery . Good luck , this always worked for me.
这个答案有帮助吗?
得分 1
1条评论:
Im having this problem i plugged the new screen in and there was a white line in the screen well i unplugged it and plugged it back in and screen doesn't come. On but the phone work's did i break the screen?
完成的
添加一条评论
The LCD is extremely fragile. Removing the screen almost certainly will damage the display, no matter how carefully it’s removed unfortunately. You likely need a new screen.
这个答案有帮助吗?
得分 0
1条评论:
Yea. I figured as much. I since replaced the screen, and the phone stopped working again shortly after. So I’ve moved on and got a used iPhone. I prefer Android, but beggers can’t be choosers...
完成的
添加一条评论
添加你的答案
William Bosco 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 27
总计 706
