跳转到主内容
加入维修社区 - 创建账户
Device repair and troubleshooting for the 7" RCA tablet released in 2014, identified by model number RCT6773W22.
My screen won't respond
How can I get my screen to respond
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
See your Owners Manual on how to access Recovery Mode as there may be options you can try. You could also try pairing a bluetooth mouse to your unit which should give you access to System Settings etc or if your tablet supports OTG, you can use a regular mouse attached to an OTG cable which is connected to the micro USB charging port. Unfortunately, imho, RCA tablets aren't that great and you may end up having to do a System Reset from the Recovery Mode menu; if this ends up being the case, all the data stored on the device will be erased and the tablet restored to it's factory settings and condition. Make sure you save any wanted data (like photo's, email etc) before resetting the device. If you have a computer, you can backup any need files to it via USB methods (USB stick, cable etc).
完成的
添加一条评论
1个答案
最有帮助的答案
Hi kimberley3940,
It may be that the tablet’s digitzer (touchscreen) flex cable connection is loose or that the digitizer is faulty and needs to be replaced.
Here’s a link to a video that shows how to replace the digitizer in your model tablet, which should help you to check the cable connection and if necessary replace the digitizer.
Here’s a link to just one supplier of the part. It is only shown to give you an idea of what it looks like and the cost of the part.
There are other suppliers online that may suit you better. Just search for RCT6773W22 touchscreen to get results.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
kimberly3940 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 106
