跳转到主内容
鉴别方式: 型号 M8541 / 5 或 10 GB 硬盘 / 中央转盘为机械部件
29 个问题 查看全部
问题已关闭
no iTunes mount
My iPod 1st generation still runs, still charges, still . . . lives. It will mount as a Device on iTunes, however.
Performed all the reset routines, the internal diagnostics, tried different machines and cables. Examined and cleaned the pins.
Any ideas? Taking it apart to look for bad solder right now.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
You said "It will mount as a device..." - did you mean to say it will NOT mount? And presumably you are using a Firewire cable, correct?
完成的
Yep, my typo. Will not mount via Firewire on any computer. Tried straight 400 and 400-800 cables.
It does charge, it does play.
I disassembled it. The solder joints on the logic board look OK at the FW port.
完成的
添加一条评论
4个答案
最有帮助的答案
Does the iPod show up in Disk Utility? Sometimes a disk that won't mount will show up in Disk Utility and can be mounted from there. (You could also run disk repairs on it there, which might clear up the problem.)
这个答案有帮助吗?
得分 1
1条评论:
DiskWarrior and Disk Util won't mount the bugger. Thanks, Mr 790.
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
maybe try erasing/reformatting the drive on disk utility and then try to connect and restore on itunes.
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 1,354
