跳转到主内容
The second generation of Scion's box-shaped hatchback.
My traction control light comes on on the freeway.
My scion is acting strange. On the freeway, at certain speeds, the traction control light comes on, and I lose speed. I try to give it more gas so I can keep up with traffic and it shifts hard and starts speeding up, and the traction control light shuts off. The Traction Control light is only on when this happens, and doesn't always come on when I lose power. Today the light came on while I was changing from one freeway to another(never got below 45 mph) and it tried to pull me into the other lane. I am a heavy truck technician, but I have never seen anything like this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You may already know this as a truck technician but here is what I have to offer.
Traction control is usually activated while driving when the wheel speed sensors detect a variance in speed between all of the wheels, and will attempt to compensate to bring them back to equal speeds. There are usually three possibilities. The speed sensor in the wheel hub is failing and sending the wrong signals, the wire connector for the speed sensor is dirty/corroded/wet, or the wiring itself has bends/breaks/cuts usually from the wheel turning or the wire rubbing over time.
I would get a good computer code reader on there if you can to see if there are any stored codes to point you to a specific wheel that could be at fault. Has your ABS light ever come on unexpectedly? ABS is activated based on the readings of the same speed sensors but during braking. If the ABS light comes on, there may be a trouble code stored in the computer that points to a specific wheel.
If you cant find a code reader or there are no codes, I would start by checking the wiring for each wheel speed sensor to the best of your ability for breaks/cuts/splits/rubbing. Then carefully disconnect each speed sensor wire connector and clean them out if needed to make sure they are getting good contact.
Please keep me posted on your fix. I would like to know what is actually at fault.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paula Blough 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 1,389
