跳转到主内容
GMC 汽车、卡车、SUV的修理和支持指南
291 个问题 查看全部
1998 k2500 suburban running rough
My 1998 K2500 suburban with a 7.4L is rough running. The ICM, the ICM connector,cap and rotor, plugs and wires, ignition coil, fuel filter were all changed with no improvements. The check engine turned off for about 24 hrs and then came on again tonight. It seems to run better and it is cold. The rough running gets worse as the engine heats up. Please help! I'm out of ideas.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @hobbytrader1 ,
Have the OBDII port scanned with a scantool to see if there are any error codes showing.
If there are it will give an idea of what is happening in the engine.
Have read that AutoZone will do this for free.
这个答案有帮助吗?
得分 1
添加一条评论
The check engine light is key here and should point you in the right direction.
It sounds like you’ve taken care of the spark side of things.
This issue could also be related to fuel delivery, air intake, the fuel/air mixture, or a timing related sensor. Examine the vacuum hose for your fuel pressure regulator. A fuel pressure test may be helpful to ensure proper pressure is attained and maintained by the fuel pump and pressure regulator. Professionally done is best but if you do it yourself take proper safety precautions and have fire control equipment handy. There is also the possibility of a faulty oxygen sensor throwing off the fuel/air ratio, or a camshaft position sensor or crankshaft position sensor negatively affecting the timing.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mike Stringham 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 81
