跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone restarts when HOME button held down, power button unresponsive
I have a donated iPhone 6s, which after many replacement parts has been brought back from the dead (screen, button cable).
I have repaired hundreds of iPhones, and never met a problem that couldn’t be solved by replacing parts.
It works wonderfully, but there are two quirks that I am yet to work out:
  1. The power/sleep button is unresponsive, despite replacing the button cable.
  2. If the HOME button is held down the phone restarts, and sometimes goes into a boot loop.
I have:
  • Replaced the button cable
* reset it
  • wiped it
  • managed to get it into DFU mode (which baffles me, as I thought the power button didn’t work… maybe it works but doesn’t respond correctly?) and updated it
Anyone fancy making any suggestions? It is not HUGELY important, but I am curious as to what might have happened here!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Have you tried using a original power button and not a cheap aftermarket one?
What happens if you unplug the power button does it reboot while holding the home button?
You might also have a bad fpc power button connector on the board!
这个答案有帮助吗?
得分 1
添加一条评论
Hey there, yes, I always use original Apple parts.
Will try unplugging the power button, good suggestion…
I think the connector is the most likely cause- although no water indicators have been set off I am convinced there has been some kind of ingress- there is residue around the button connector…
Will get get back to you!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pabz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 39
