跳转到主内容
加入维修社区 - 创建账户
Kenwood DNX571HD 是一款车载中控立体声主机,配有 6.1 英寸宽屏触摸屏、影音导航系统、蓝牙以及高清和卫星收音机。兼容安卓和苹果智能手机。
Head unit will not power up.
I have a Kenwood DNX570HD that has been working fine and just stopped working. It will not power up. The red triangle is off when I start my truck however if I push that button it will light up but then goes back out after about 5 minutes.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
11条评论
Can you please add pictures or directions of exactly which board it is and how do you remove the strips from the board
完成的
The daughter boards are no longer made. If anyone is interested in selling their broken units hmu huntspaintingokc@gmail.com
完成的
In need of a daughter board myself
完成的
What are you wanting for it?
完成的
Robert Hunt, sorry just saw you replied here I sent you an email a while back make me an offer. I don’t really know what it is worth without the daughter board working. My email is shaner12@gmail.com.
完成的
显示更多的6条评论
添加一条评论
3个答案
已选择的解决方案
You can actually take out the daughter board and use a heat gun to float the solder. Thats all it is 90% of the time. Just have to have a little patience and skills to take it apart.
这个答案有帮助吗?
得分 1
3条评论:
Correct..unfortunately, kenwood designed this as the farthest thing away from the fan in the whole deck. By chance do you have any idea why a similar model came with touch screen would work in a split screen mode? Half of the screen is fine and half of the screen is grayed out
完成的
Where is this daughter board?
完成的
The daughter board is to left just under the disc unit. You have to take the discplayer out and use a heat gun and apply heat to this board. Heat gun works best but don't get it too close. Do this for about 2 minutes and that should be good. Let it sit and don't move it for about 20 minutes. After that the solder should have time to settle. I have done this numerous times and it has worked. Good luck.
完成的
添加一条评论
Have you tried reseting it??
这个答案有帮助吗?
得分 0
4条评论:
Yes, I have tried to reset it multiple times. I have checked both fuses and also checked all connections to make sure nothing is loose or not making a connection.
完成的
This is all about resetingand doing a hard reset
https://www.youtube.com/watch?v=judksnNu...
完成的
Thank you for the suggestion. I actually used that exact video to do the reset.
完成的
My Kenwood DDX9702S I bought off a buddy and no blowed fuse all connectors good just red light blinking
完成的
添加一条评论
Hey bud. I had one of these exact units do the same thing, so i bought one with a broken screen off of ebay fairly cheap. What the problem ended up being is called the "daughter board", which you can purchase from a site called pac parts, they run abou $145.00
这个答案有帮助吗?
得分 0
1条评论:
Pac parts offered one not too long ago. I have a broken unit with bad daughter board if you need it for anything else. aillsauto@msn.
完成的
添加一条评论
添加你的答案
Shane Houghtaling 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 60
总计 42,060
