Why wont my screen turn on
Accidentally dropped and now the screen wont light. not sure if even turning on
Onces dropped I would think you have an damaged screen.
You have two parts to the screen The digitizer (the outer) and the LCD (the inner) Usualy the digitizer part goes and the LCD would be OK To know if your LCD is OK see if you can see a display on it . You may have to chage it if the battery is dead
这个答案有帮助吗?
This did not help. Screen is black and Kindle is fully charged. Cannot see display at all
Hey Bea! I sorta understand your issue here, but if the screen stays black, you really cannot know if its charged! It could be a problem with the cord, or the charging port on the Fire, and you can't really know. edigitcom's advice helps if you're prepared to take the Fire apart, maybe install a new screen. Otherwise, trade in your Fire to Amazon!
You need to find out if it’s turning on or not. Try plugging it into a PC and pressing the power button after charging. You should be able to tell if it’s booting up or not. It could be that the LCD cable came loose when you dropped it.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 277
