跳转到主内容
加入维修社区 - 创建账户
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
WIFI issues after screen replacement
I dropped my phone a few weeks ago and it shattered the screen, lost functionality of the home button but it still operated fine up until the screen was replaced. I did it myself to save on costs. Removal went pretty smooth, i was able to get the old screen out and the replacement came with the parts already installed so i didn’t have to bother with swapping over the existing pieces. I did lose the ability to use the touch id but i can live with that. I decided to re install the os and start fresh after the repair work. Once i got to the part where i needed to connect it to my WIFI i noticed it could not locate the signal from my room.. But if i stood near the router it worked flawlessly.
I had no issues with the wifi antenna before i replaced the screen but now it seems as if the antenna has become unplugged or has been damaged.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I started taking the phone apart today as the new parts should be arriving tomorrow. While taking the phone apart i noticed that the cable connecting the logic board to the 5GHz antenna was severed right after the logic board connection. I recon i probably broke the cable while i was removing the front panel assembly cable bracket for the screen repair. This would explain why the wifi still worked, but not at a reasonable distance away from the router.
完成的
添加一条评论
2个答案
已选择的解决方案
Replacing the 5GHz antenna solved my issues. I no longer have to be in the same room as the router; full signal across the house.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
I’ve had this antenna rip once but only when taking the logic board out of it’s housing on the iPhone 6 plus:
There are roughly 3 screws on that antenna but they usually don’t get touched at worse the screws for it may be a bit loose and need to be tightened after the phone getting dropped over time. Then the other part is the antenna cable.
That part is for the 5.0 GHz side. I’m not exactly sure where the 2.4 GHz one is but I think it’s the one that connects from housing to back of board top left.
iPhone 6 Plus 5G WiFi 天线更换
iPhone 6 Plus 5GHz Wi-Fi Antenna
Replace a torn or missing Wi-Fi antenna compatible with the iPhone 6 Plus model #A1522, A1524, A1593. Fix unreliable connectivity to Wi-Fi service.图片
产品
$23.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
DKM802 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 34
总计 4,903
