跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
screen rotation not working after battery replacement. Flash works
I replaced the battery in my iPhone 6 with a Coolege knock-off. After reassembly, at first the screen orientation would no longer rotate to landscape and the flash/flashlight would no longer work. I took it apart again and made sure all cables were securely connected. Now, the flash works fine again, but the rotate is still locked into portrait mode.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Hi @deaconblues
Did you check your settings to make sure that lock rotation wasn’t accidentally turned on during your repair? You can find this setting in the control center that comes up after swiping up from the bottom of the screen:
这个答案有帮助吗?
得分 1
2条评论:
Thanks Jeff. I tried your suggestion (with high hopes you were right), but alas, 'twas already unlocked. I even tried locking and unlocking it again, but again, to no avail! Thanks again!
完成的
I was really rooting for an easy fix! You could always try a backup and reset to rule out any additional software problems.
It's possible there could be an issue with the accelerometers on your logic board. You should check this area for any kind of physical damage:
https://cdn.macrumors.com/article-new/20...
Other symptoms of this chip failure include issues with the Compass app and level functions of the "Measure" app.
Hope that narrows it down a bit
完成的
添加一条评论
same problem: screen rotation not working after battery replacement! shake to undo, compass and level functions still working fine though…but the screen doesn’t rotate anymore in any app. already checked the “block rotation“ in control center. I’ve been super concentrated durning the replacement I should have done everything perfectly…there is no way I damaged the gyroscope…any idea??
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
deaconblues 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 4
总计 177
