跳转到主内容
Device and repair information for the Behringer Eurolive B212D speaker system.
Why does my low frequency speaker have static noise?
Low frequency speaker has static but doesn’t sound blown, wondering what to replace to fix this issue.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Thank you! I will check and let you know the results!
完成的
You're welcome and good luck! :-)
完成的
添加一条评论
1个答案
已选择的解决方案
If only statically during audio playback, check the internal speaker wires to see if loose connection, stray wires are causing the problem due to the vibrations of the speaker box. Also check your audio input cables to the unit. Do a visual inspection of any circuit boards for cold solder joints, cracked solder joints, overheated spots, bulging capacitors etc.
If static is present with no audio signal applied, then using a signal tracer or oscilloscope to trace through the speakers circuitry should be of assistance in tracking down the problem.
If static begins when hooking up your external PA devices (ie mixer, mics, mic cables etc) then they will also need to be checked one by one to eliminate them as a possible source.
The following may also be of use to you:
https://old.reddit.com/r/audiorepair/
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
添加你的答案
Justin Burrell 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 742
