跳转到主内容
Curved screen LED monitor released by Samsung in May 2015, identifiable by the model number S27E510C.
4 个问题 查看全部
Blackness on part of screen and cracks
This morning my Samsung 32in curbed monitor fell and cracked under the screen (no outside damage) and that side of the screen is black. Is there a way to fix this without paying bcuz it could just be a technical issue even though I fought that.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
yup, these are super easy to break. i broke 2 of these monitors. i have traveled with other monitors all over the world but these are soooo breakable. So far i have just bought new ones to replace the broken ones.. tigerdirect has refurbished ones for $149
完成的
添加一条评论
2个答案
You likely cracked the lcd (liquid crystal display). Unfortunately once the liquid is out, there's no easy fix and you'll have to replace the display.
这个答案有帮助吗?
得分 0
添加一条评论
Brownbailey may be correct. Computer monitors are considered to be Field Replaceable Units, which means that they only get replaced by technicians, not repaired. Opening some types of monitor without the right equipment may even be dangerous because they can still hold a charge even if turned off.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MyMonitorBroke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 31
总计 758
