跳转到主内容
Power button gets stuck from time to time
Occasionally, power button gets stuck on triggers double-click when pressed once. I suspect this is a “mechanic” issue since the phone fell down several time.
Is it easy/makes sence to disassembly Nokia 6 and fiddle around with power button to try fixing the issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
this would require you opening the device carefully with the right tools and using a tiny piece of double sided tape to hold button in place where it belongs before carefully closing phone insuring you dont dislodge button, ive personally cut delicate ribbon cable attaching button and had to spend $2 us to replace
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dima Naboka 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 444
