What cables do I need to connect my iPhone XR to the projector?
I don’t know what cable I need to connect the projector to my phone
Hi Emalee, if you want to connect your iPhone to the projector with a cable then you will need a USB Type C to HDMI cable which will cost you around $10 to $30 in United States. But it has a disadvantage you cant move your iPhone now.
There is another way to connect the iPhone to the projector wirelessly, using a wireless display dongle, so you can move your phone while it’s connected to the projector.
You can watch this video on how to connect a phone to a projector wirelessly, hope this is helpful.
这个答案有帮助吗?
Even this topic is already 4 years old (and possibly dead for the OT) i would like to enhance the solution for other readers with the same problem.
There are original Apple or 3rd party adapters on the market to connect your iPhone with a projector, depending on the connections the projector provides:
To make it wireless you can use the solution from above mentioned video, or you simply buy an Apple TV device and connect it via HDMI to the projector. More costly, but everything inside the Apple ecosystem.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 17
总计 236
2条评论
What kind of interface(s) does it have?
由 Rosa Avrigari 完成的
Being an iPhone options will be limited, check the manual to see whether you can connect it via Bluetooth or wifi
由 adam stepek 完成的
