跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Phone is power cycling from apple log to off
Phone power cycles between off and apple log when plug in to charger and battery isn’t charging, try to DFU or Recovery mode phone but iTunes doesn’t acknowledge phone plug to PC. Should I try to use a charged battery to update software or is there something else that I can do ? I’m trying not to have to open the phone. Thanks in advance for your answer.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
boot looping is typically caused by three things in most cases. Battery, motherboard, software, from my experience in that order of how likely it is to be the problem (excluding certain device issues, such as iphone 7 home buttons being ripped). if you’ve already tried software, and it won’t install, you’ll end up having to open the device to try a known good battery. if that doesn’t work, you can try to frankenstein a charge port on the device (no need to fully install, just connect it) long enough to attempt the factory reflash.
这个答案有帮助吗?
得分 0
1条评论:
Thank you, the battery was the solution.
完成的
添加一条评论
添加你的答案
Rudy Camps 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 987
