Best Samsung LCD matrix. LTH133BT01 vs LSN133BT01
As far as I know Samsung matrix is better than LG for MacBook Air.
There are two kind of Samsung matrix available - LTH133BT01 and LSN133BT01.
Which is the best?
Unlike the older MacBook & MacBook Pro series the MacBook Air display is ultra thin which is why its display is not as good. To add to this each display has a code which the system leverages to ID its dimensions and scan rate.
I haven’t tried substituting displays in the Air series so I can’t tell you if a thicker display will work and the limitations of the lid may prevent it from closing.
Given the risks and the expense it might make sense just getting a newer MacBook Air as Apple has improved the screen used in it quite a lot!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 101
Lets backup here a bit...
Is the screen damaged in anyway or are you just looking for a better display?
If you are looking for a better display what is it you are looking for Brighter, Color saturation or Gamut? Or denser pixels?
由 Dan 完成的
@danj I am looking for a better display which shows letters and text more naturally. Brightness is not important. I love LTH116AT01A04 on my old MacBook and I am looking something very similar.
由 Misha Krasnorutsky 完成的
