跳转到主内容
诺基亚E63是一款于2008年发布,支持四频GSM及UMTS网络的移动电话。
Why is My Nokia e63 not charging?
please i need help and advice.
I plugged in my e63 today and it showed that it was charging. After that the screen went off and it refused to on. Before the, the charging port worked perfectly.
I had to boost the battery with desktop and i switched on the phone. I discovered that if i plug the phone, the blue light indicator on the charger switches off and when i remove it, it switches back on. Sometimes i will plug the phone and it will charge for a second and immediately stop charging.
Please what can i do?? Can i fix it or should i leave it and continue charging it using desktop??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
No on mobile switch off
=== Update (08/11/23) ===
Charged but no on mobile
完成的
添加一条评论
1个答案
It could be a few thinks
The battery itself
The cable your are using
The dock charging connector
Are you sure the screen is itself OK??
Do you have to move the charging cable in the port to get it to charge ??
can you move the charging cable from side to side in the charging dock connector??
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dillon Micheal 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 6
过去 30 天: 10
总计 904
