跳转到主内容
The Logitech G700s is a wireless gaming mouse that connects to a computer using a USB wireless receiver. The mouse has 12 programmable buttons, and has a DPI of 200-8200
I got a new mouse and it wont scroll
I changed the settings but it still wont work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
If you haven't already I would download the Logitech software associated with the G700 then check the key-binds on it. My Razer Naga had the same problem, but fixing the key-binds fixed it. If it doesn't work I would recommend contacting Logitech.
完成的
添加一条评论
1个答案
The scroll wheel rotates inside a transparent plastic piece. Remove and clean the transparent plastic piece with alcohol, both sides. The optical sensors infrared light needs to cross the two windows on the plastic piece and the wheel. If the plastic is dirty, the scroll wheel won't work. The dirt comes inside easy from the wheel. Make sure that the tiny slots inside the wheel are clean too, they look like bicycle wheel spokes.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rose simmer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 276
