跳转到主内容
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
Power Button does not click after re-assembly
After putting the top on, the power button doesn’t click. It clicks fine until i clamp all the plastic clips around it in. Screwing it in or anything like that does not help either. Nothing seems to be in the way of the button either
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Just a thought. If switch uses mounting screws, maybe try putting some plastic washers between the heads and the computers frame to see if that makes a difference. My stance for my own personal equipment, if a solution works, it works and that is good enough for me. :-)
完成的
添加一条评论
1个答案
Try reseating the ribbon cable that goes to the buttons. Most likely it's slightly out of position or something.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Thomas MacGregor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 124
