Hi, I have personally replaced my own iPhone 5S battery and from the sounds of what you are experiencing, there could be two problems. The first is when you re-attached the ribbon cables for the screen that you didn’t seat the cables into position properly, if this is the case, then you may have to open your phone again to check the cables. The second thing that may have happened is screen damage. To much pressure on the screen when the phone is open can cause damage to the display. If the screen is warped or bumpy then it is most likely a broken screen. Any more details and I will be willing to assist.
Suspect improper flex cable seating(s) especially the digitizer (touch) flex cable. Maybe review your reassembling procedure to make sure you didn't miss anything.
https://www.imore.com/how-replace-batter...
由 prop man 完成的
