跳转到主内容
The Super Nintendo Entertainment System (SNES), or simply the Super Nintendo, is a 16bit gaming console released by Nintendo in 1990. The Super Nintendo was one of the best sellers of its time and still has a large fanbase today.
106 个问题 查看全部
Why do I have a black screen and why does my TV make a buzzing noise?
my Super Nintendo is receiving power(AKA the light is on.) but i get a black screen and i can hear a small buzz coming from the speakers. has my motherboard gone bad or is it something else?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
From what I have been reading it would appear that the “72 Pin Connector” is a common source for problems. Might want to check out (or similar) the following:
http://classicgamesblog.com/2011/03/05/h...
And while you have it apart, do a visual for for bulging caps, burn marks, dry or cracked solder joints, exploded components etc
完成的
could it be a short in the power cable? i laid it length wise and i got a little black screen. at least briefly.
完成的
@propman I had to shove a piece of paper in between the cartridge and the side wall of the slot...
完成的
@Jordan Fryman Which I suspect indicates the contacts are intermittent. Suggest you try what is recommended regarding the cleaning and readjust any pins that need realigning on the connector.
完成的
添加一条评论
1个答案
已选择的解决方案
the cartridges were dirty "(even though i already cleaned them :| ) and the pins on the console itself were pushed outward. Works perfectly now… but i also have a problem with my N64 too
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jordan Fryman 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 3,012
