跳转到主内容
电脑显示器维修。
Samsung Monitor with black vertical line
Just wondering if anyone can help me with this. My Samsung C24FG73 has one black vertical line on it. I’m happy to take the monitor apart and fix it but I wouldn’t know what part to replace. Any advice would be appreciated
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
If you have eliminated your computer and video card as a source of the problem, probably would be a good idea to open up the monitor for a visual inspection of obvious malfunctioning components (for example, bulging capacitors, burn marks, etc. Probably would help others to identify the problem by posting a screen shot of the black line.
完成的
Hey thanks, I just edited the original post with some pictures. I thought u had them up before but must have missed them.
Yeah I guess that your probably right will have to take a look when I get a sec to see if I can spot anything
完成的
Wow, man. It looks terrible. Have you managed to solve that issue? Hope you have. I’d be grateful if you kept us updated on your problem. My friend used to have the same issue, but I can’t remember how he solved it. I guess he just bought Dell’s monitor instead. As far as I know, he has this monitor https://productz.com/en/dell-s2419hgf/p/.... Actually, I bought the same one. I think Dell makes the best monitors on the market, so I’d highly recommend you replace your monitor with Dell’s one. Still, tastes differ. So, I’ll be waiting for your reply.
完成的
添加一条评论
4个答案
已选择的解决方案
Hi @tralph ,
Sometimes this can be caused by a loose tab connection on the display panel itself. The connections are very fragile.
Sometimes it can be fixed by just pressing very gently down onto the tab so that it remakes the connection but you have to get to them first.
Here’s a link to a video (there are plenty of others) that may help.
这个答案有帮助吗?
得分 1
1条评论:
Hi, i've got the Samsung Monitor as well (Samsung monitor S32D580T) with Vertical Lines popping up on the screen when connecting it to a Laptop, Please help if this can be fixed
完成的
添加一条评论
I had a black stripe down the left hand side and it seems Windows adjusted my display settings without me touching them so that the settings on my laptop matched my monitor. Went in and changed it to “Show on two displays only” I turned my monitor off and then back on again and it was resolved
这个答案有帮助吗?
得分 1
2条评论:
can you show me how to do it exactly?
完成的
we tried updating the graphics driver but that did not work. says its up to date. no other option to change settings and the line just got worse. we're using a laptop by the way. i don't believe that should matter, right?
完成的
添加一条评论
Just check for the flex cable inside the back of your monitor. You will have to open the back panel and have a look right there. probably a loose connection, or defective cable is your issue.
这个答案有帮助吗?
得分 0
添加一条评论
Similar issue, left hand side. Dotted line. Updated my graphics driver and it seemed to go away during that process
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tom 将永远感激不已
浏览统计数据:
过去 24 小时: 24
过去 7 天: 167
过去 30 天: 746
总计 42,342
