跳转到主内容
Audio/Video receiver, originally manufactured by Pioneer in 1998. Features include 100Wx5 amplifier, 6 channel input, Dolby Digital, DTS & DSP, S-Video switching, 4 digital inputs, 1 digital output.
Relay is clicking on and off
Hi,
I suspect my Pioneer VSX-D608 has a power supply issue. When I turn it on from standby, the screen turns on and there’s sound from the speakers. But after a few seconds, or after I turn the volume up, I hear the main relay from the power board click and after that the receiver restarts.
I wonder how to troubleshoot this issue - what is the main reason for the relay switching? is the system shorted somewhere or is it a bad component?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
8条评论:
Here is a service manual that may be of some help: https://www.manualslib.com/manual/796922...
Keep us updated, this is an interesting issue
完成的
@travisjfox thx, already got the manual. I have knowledge in electronics (I'm an electronics engineer) but no hands-on experience with working with complex analog circuits. I am wondering how to approach this and what I should look for first, just to get started
完成的
@yoniizu If you have the remote that goes with the device take the batteries out and turn the device on manually. I've seen dying batteries in the remote cause something similar in a Phillips brand player
完成的
I tried both with and without the remote, same problem...
完成的
@yoniizu Were the batteries removed from the remote?
完成的
显示更多的3条评论
添加一条评论
1个答案
It is called a speaker relay. It is there to protect your speakers from DC current burning them out. I could be that it just needs adjusted to lower the DC offset 99% of the time when the red protection light comes on or the relay does not make a sound or turns on then off, it is a bad component. It will need to be looked at by someone who is familiar with electronics.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jonathan Izutskiver 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 30
总计 2,598
