跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
What Repair Parts Are Needed?
Regarding an iPhone 6s Plus, model A1634. The audio connection jack at the bottom of the phone (next to the charging port) does not return to the built in iPhone speaker when an external speaker connector is removed from the female connector port. As a result, the phone remains in “Headphone” mode at all times. What part do I need to replace?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It could be a software issue. You could try updating or just restoring the phone all together. If that doesn’t do anything I would replace the charging port and headphone jack ribbon cable. Here is a link: iPhone 6s Lightning Connector and Headphone Jack
iPhone 6s Lightning Connector and Headphone Jack图片
产品
$19.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
loudanzico 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 4
总计 40
